This command disables reload-delay on Multi-switch Link Aggregation Group (MLAG) ports.
MLAG reload-delay is disabled by default.
There are cases where MLAG ports comes up quicker than ISC ports after a switch reboot causing traffic loss during this time gap. This command disables this timer feature.
The following example disables the MLAG reload-delay timer:
# disable mlag port reload-delay
This command was first available in ExtremeXOS 22.3.
